Dreaded po300
Old May 25, 2013 | 10:45 AM
Dwhite96's Avatar
Dwhite96 is on a distinguished road
The acynoms I got were from the Hayens Repair Manual. CMFI is Central Muliport Fuel Injection and CSEFI is central Sequential Electronic Fuel Injection.
Old May 25, 2013 | 10:50 AM
Dwhite96's Avatar
I have purchased the MPFI and will install today. Thanks .
Old May 25, 2013 | 01:27 PM
LannyL81's Avatar
It figures that I had it backwards in my posting.....I should know better than to think without coffee on a Saturday morning.
Good to hear you got the good one....much, much better than the poppet style nozzles.
Old May 27, 2013 | 07:58 PM
Dwhite96's Avatar
Well, I installed the new injector spider with fuel regulator. It runs better but it still hesitates once in a while during the day. It still stumbles once in a while during the day. I think there still must be a vacuum leak somewhere, or could it have something to do with the transmission? Every once in a while it will stumble, ie; I will be holding a steady speed and the RPMs will increase about 400 then go back down. Just not sure in which direction to go from here. I appreciate all the input everyone has given.
Old May 28, 2013 | 09:04 AM
spittybays
Guest
Posts: n/a
Are you still getting the code.
Check tranny fluid for the slipping issue.
Vacuum leaks like to manifest as surging at idle or high rpm at idle.
Old May 28, 2013 | 09:31 AM
jimspahr@msn.com's Avatar
OP. what is the P0300 code in English?
Old May 28, 2013 | 11:11 AM
spittybays
Guest
Posts: n/a
multiple random misfire
Doug W
Nov 24, 2010 01:13 PM
High_Speed
Sep 21, 2010 09:16 AM
das96blazer
Feb 22, 2010 11:11 AM
dragynaz
Feb 22, 2008 09:15 PM
levi
Nov 30, 2007 02:04 AM
