drl and healights
Old Sep 11, 2009 | 02:29 PM
brokenblazer's Avatar
brokenblazer is on a distinguished road
Default drl and healights
Hi guys i just discovered this site while searching all over for a fix to my problem. i have a 1995 blazer 2dr 4x4, the problem i'm having is my drl kept shorting out my illum fuse. i opened my dash to look at the wiring and found no shorts. it is hard for me to word this correctly so bare with me.
when my drl use to work i noticed they didn't work off my parking light switch but actually off my dimmer switch, when i opened the dash i saw that the brown wire for the drl also went into the headlight/parking light switch.
here is a picture i found of how it is set up
so i'm wondering if it is the headlight switch went bad and it is drawing all the power through the dimmer switch for the drl that is causeing my problem......because i don't get any power from my headlight switch to the brown wire.......i tried combining the brown(drl) with the yellow(headlights) to get power to the drl when it is dark and i have my headlights on and it worked for several hours but then i noticed the headlights just flicker now and it sounds like it is trying to arc inside the headlight switch....i have since just left it alone with the wires out till i can get a lil help
Old Sep 11, 2009 | 05:50 PM
awe341's Avatar
awe341 is on a distinguished road
There should be a DRL relay in the fuse box under the hood. I would check that first before anything further with wiring in the dash.
Old Sep 12, 2009 | 09:46 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Im thinking that the drl wire there only wants power when the headlights are on. I think its more to signal the DRL module to shut off the DRL and run the headlights off the switch and its relays.
heeb2424
Apr 5, 2012 07:29 PM
tornado_735
Jun 22, 2011 01:26 AM
dew88
34
Jul 29, 2009 07:55 PM
NVANZEE
Dec 22, 2008 06:18 AM
dave5point0
13
Nov 18, 2008 04:13 AM
