DRL not working after radio install
Old Feb 24, 2015 | 07:56 PM
idriveblazar's Avatar
idriveblazar is on a distinguished road
Default DRL not working after radio install
Hello, I drive a 2000 Blazer LS and did a radio install today, I have a 2 channel amp so the need to wire all the speaker wires to the harness seemed pointless. Does the light sensor receive power from one of the speakers? Or did I possibly unplug a wire somewhere?
EDIT: My brights, headlights, and running lights all work when manually turned on, this just happened today and I can tell it is going to be a hassle if I don't fix it.
Old Feb 24, 2015 | 09:14 PM
richphotos's Avatar
You could consider yourself lucky, since this is a common mode to disable?
Otherwise, no, it does not get power from a speaker wire from what I believe.
You could have unhooked something when installing the radio. I would pull the radio and check behind to look for anything that could be unhooked.
Old Feb 24, 2015 | 09:37 PM
I don't want it disabled, and do you know where exactly I'd look for wires to have unattached from?
Old Feb 24, 2015 | 10:05 PM
richphotos's Avatar
I do not know the exact location. I would search behind the radio real well for anything that is not hooked up..
That is too much of a coincidence that you put in a radio and they stopped working.
Old Feb 25, 2015 | 11:19 AM
There was already an aftermarket radio that I have removed several times, I've looked around today and saw nothing at all.
Old Feb 25, 2015 | 12:12 PM
Are you referring to the Autolamp feature not working, or the daytime running lights are not working? Two different systems that control the headlamps. The Autolamp light sensor is in the right front speaker grille. Pull the grille out and make sure the sensor is attached to the grille, and the connector is plugged into the sensor.
Old Feb 25, 2015 | 01:34 PM
I'm not really sure how messing with the radio effected it, but when you find out what happened let everyone know, you may have found another way to disable the system lol I hate the feature personally... If I want the lights on, I'll turn the darn things on myself!
Old Feb 26, 2015 | 04:38 PM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
blazen, if you want to disable the autolights, double click your dome-light override button. That should then give you manual control with the selector.
If its the DRL's you want to disable, can't help you there
Old Feb 27, 2015 | 02:46 PM
I do, every time I hop in the truck lol gets old, I want it to PERMANENTLY be disabled. I don't want ANY of my lights to come on at any time unless I turn the switch
Old Feb 27, 2015 | 02:59 PM
Hmm I wonder what I did then because I did that once and its stayed that way until I double clicked it again, weeks later.
This is on my 01 Jimmy
