DRL will not work?
Old Oct 8, 2008 | 04:10 PM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default DRL will not work?
DRL lowbeams do not come on during daylight but if I click to high beam the high beams come on during day light.
Low beams come on when sensor sees low light condition and low beams come on with manual switch.
Replaced DRL relay did not help.
Would the DRL module be the problem? Is it easy to change? It isUnder the dash somewhere?
1999 S10 Blazer 2 door LS 4.3L 4x4
thanks
Old Oct 8, 2008 | 04:29 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: DRL will not work?
if you have your owners manual for that truck the directions are in there for setting and resetting the DRL`s If you dont have the manual lemme know
Old Oct 9, 2008 | 11:27 AM
AJBert's Avatar
I could be very possible that a previous owner disabled the DRL. There are a couple of ways to do it but I can't remember which way is which for a 99.
Old Oct 9, 2008 | 02:37 PM
blkblazer's Avatar
Have owners manual, nothing about resetting DRL only description on how they operate. In Canada if that makes a difference with owners manual.
Old Oct 9, 2008 | 03:56 PM
blkblazer's Avatar
Re previous owner disabling DRL. No they used to work quit for some reason.
Old Oct 9, 2008 | 04:15 PM
2002XTREME's Avatar
ok heressome info from my manual... First off does your blazer have a button on the dash under the headlight switch that says dome override? if so let me know, if not, then my manual says in big letters ( The following does not apply to vehicles sold in canada) i`m not sure what part their actually speaking of.. let me know either way..
Old Oct 9, 2008 | 05:03 PM
blkblazer's Avatar
Yes have the override button.
Old Oct 9, 2008 | 05:11 PM
2002XTREME's Avatar
ok this is what manual says turn ignition to "run" position (do not start of course),,,( To return to automatic mode,push the dome override button 4 times within 6 seconds( a chime will sound) or turn the ignition to off and then to run position again!!!! Let me know if that works....
Old Oct 9, 2008 | 07:36 PM
blkblazer's Avatar
Will give it a try tomorrow in daylight. Let you know.
Old Oct 10, 2008 | 10:23 AM
blkblazer's Avatar
No chime but seemed to work. Maybe new relay and the reset method were both needed.
Thanks
