Dropping a zr2 fuel tank question
So last night my truck died wile driving it. Sputtered for about 2 miles then dead. The fuel pump will not even prime when the ignition is turned. I have tried running a 12v bypass to the pump directly and to the direct on in the fuse box. So I'm pretty sure it just flat out died. Any thoughts or work arounds are welcome.
Ok so I had a 96 four door and I dropped the tank on that one. So I know some of the basics for the drop. My question is this. On the 4 door there is a evap peice up near the front that if you don't know about you will snap, is this same part present on the 2 door model? If so where is it located on the tank? Also any helpful tips on the drop would be appreciated as I'm sure there will be something I don't know about when I go to do it this weekend.
Also is this a MU113 pump or is it a different model?
Redtortoise38
Jun 16, 2015 12:00 PM
ShaneInsane
Dec 12, 2007 09:08 PM
