dual exhaust
Old Mar 5, 2012 | 03:39 PM
sxtreborn's Avatar
sxtreborn is on a distinguished road
Default dual exhaust
I just had dual exhaust put on my wife's 2000 blazer and was wondering why is there more air flow on one side than the other. It is a true dual one pipe per side and the side with the longest pipe has more air flow out of it.
Old Mar 5, 2012 | 04:26 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
if you run a h-pipe or x-pipe they will scavenge from each other and will run better
Old Mar 5, 2012 | 05:33 PM
AJBert's Avatar
X2
This is what you should have done in the first place.
Old Mar 7, 2012 | 12:57 AM
onebadsuv's Avatar
onebadsuv is on a distinguished road
Easy fix - just go back to the shop that installed the dual system and ask them to weld in an equalizer pipe - normally placed after the cats and in front of the mufflers . Will also boost bottom end torque I've found ...
Old Mar 11, 2012 | 07:34 AM
LannyL81's Avatar
Default Picutres...???
Those of you with dual exhaust....do you have a 4wd or 2wd? I would sure like to see a dual exhaust setup on a 4wd 4 door Blazer. I have wanted to do this as well, but I see no good routing of the pipes due to transfer case, fuel tank, etc.
Pictures????
Old Mar 11, 2012 | 11:28 AM
Akron Red Neck's Avatar
Akron Red Neck is on a distinguished road
I have found that every time I get under the hood or underneath the chassis of my Blazer I wonder if this is what it is like working in the dashboard of a Space Shuttle.
Old Mar 12, 2012 | 04:53 PM
b-man85's Avatar
b-man85 is on a distinguished road
Please post a pic or two I want to do this to my 2001
the_mind
Headers, Intake, & Exhaust
26
Nov 26, 2008 12:45 AM
lucky03602
Sep 5, 2006 10:45 PM
Mylo_T_Cat
Mar 19, 2006 04:56 PM
blue_green_rider
Nov 17, 2005 07:11 PM
downhilryder
Oct 27, 2005 02:21 AM
