ECM / PCM fuse location ??? 95 Blazer
Old Jul 8, 2012 | 07:55 PM
miztic2u's Avatar
miztic2u is on a distinguished road
Default ECM / PCM fuse location ??? 95 Blazer
Hello everyone.. I have a 1995 Chevy blazer 4w drive 5/95 ..
Can someone tell me where the fuses for the ECM or PCM are located? I have a scanner and was going to scan my blazer but it says there is no response from the Blazer .. So I'm thinking it could be a fuse. My check engine light does not come on even when I first put my keys in and turn to start all Lights in the dash come on but I see no check engine light .. What would cause this? Is it the Fuse...
Old Jul 8, 2012 | 08:18 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
I know some are under the hood in the box over the driver's fender well in my friends 97 jimmy so I'd start there, & plz don't double post just makes for a cluster **** & does mean you get an answer any faster. good luck on ur issue.
Old Jul 8, 2012 | 09:28 PM
1995 was a transition year, 2 different fuel delivery systems and 3 different OBD systems were used, (one of the reasons Olds did not produce Bravada in 1995).
Which data link under the dash do you have?
Also, is the PCM mounted on the passenger side inner fender on top of the coolant reservoir?
Make sure you check all fuses.
Old Jul 8, 2012 | 10:19 PM
miztic2u's Avatar
Are the Fuses at the computer pcm or Where ? The Check engine light does not even come on when i turn my key ..would that cause that to happen?
Old Jul 8, 2012 | 10:20 PM
miztic2u's Avatar
Sorry didn't mean to double post..
Old Jul 8, 2012 | 10:21 PM
miztic2u's Avatar
Originally Posted by miztic2u
are the fuses at the computer pcm or where ? The check engine light does not even come on when i turn my key ..would that cause that to happen?
eobo / obdii
Old Jul 10, 2012 | 04:09 PM
If a fuse is blown, the check engine light and data link connector could both be inoperative. There may or may not be an underhood fuse panel on yours. If there is, it's on the driver side close to the radiator support, in plain sight. Check both terminals of each fuse in both fuse panels.
Old Jul 10, 2012 | 05:37 PM
Reed185's Avatar
Reed185 is on a distinguished road
eobo / obdii
Mine Check engine light doesnt come on either
Old Nov 4, 2025 | 07:28 PM
tmalonty1's Avatar
tmalonty1 is on a distinguished road
I have the same 95 Blazer with the OBDII data port but the OBDI data protocol. Like the OBDI where you can jump the A & B Terminal at count service engine light flashes to redeem codes, can you do this with the OBDII data port to get fault codes. If so, which terminals should I use.
danthony428
Performance & Brainstorming
Mar 3, 2015 03:26 AM
miztic2u
Jul 8, 2012 07:21 PM
roddy
Jun 28, 2012 04:52 PM
Magmotor
Jun 4, 2011 03:34 AM
johnny_5
Mar 26, 2007 07:52 PM
