Efficient and preventative Maintenance
Old Apr 23, 2020 | 04:21 PM
MidCititesSam's Avatar
MidCititesSam is on a distinguished road
Default Efficient and preventative Maintenance
Just bought a 2000 Blazer LS 4 Door RWD as a project car
I am starting off by replacing the power steering pump and the steering box. Next on my list is the turn signal switch, only my high beams work and after replacing just about every part it could be this is the only other possibility i have found.
My question is, while I have things taken apart is there any other parts that could be swapped out during the process that would save me time in the future or preventative maintenance that could be accomplished at this time?
My AC compressor/system is going to be changed later this year. I have never done a turn signal switch before but if there is anything its connecting to that can get finicky later on in life i would like to take care of it now. Thank you!
Old May 12, 2020 | 01:56 PM
puttster's Avatar
On my blazer it is easy to put the headlight assembly in wrong, so that the low beams point up like high beams. Might be worth checking out.
tony991
May 21, 2020 09:31 PM
sifd4x4
Oct 26, 2010 12:56 PM
deltas69
Jan 28, 2008 08:21 PM
WyteNyte
Feb 16, 2006 05:32 PM
kccapt
Nov 23, 2005 01:34 AM
