EGR sensor #3
Which sensor are you looking for specifically. Your choices are B1S1, B2S1, B1S2, & B1S3. B1S1 is on the driver's side down tube of the y-pipe. B2S1 is on the passenger side of the y-pipe just ahead of the 'Y'. B1S1 & B2S1 feed AFR data to the PCM to modify the fuel delivery. B1S2 is directly in front of the catalytic converter. B1S3 is directly behind the catalytic converter. Both B1S2 & B1S3 are catalyst monitoring sensors only and have nothing to do with fuel delivery.
What codes are present that are leading you to the #3 sensor..?
Kyle, the Autotap told me egr sensor# 3. Don't recall the bank. I reset the check engine light, so will I have to wait till it comes on again to get the codes and the bank # ?
I'm still learning this auto tap tool.
I tried to replay it but its blank. I musta goofed up some were.
I'm going to go hook up right now and check.
I have it hooked up now, but the codes got cleared when I cleared the check light. Idle is a little rough though.
I do not think that the Autotap can retrieve code history. I'd suggest you drive it until it pops back up and then let us know what the code is.
On the file that you generated, was it just the configuration file where you setup your gauges & tables, or did you actually record some operating paramenters while the vehicle was running?
