Electrical buzzing noise coming from Ign. swith box under dash...
Old Dec 12, 2010 | 07:10 PM
The89Blazer's Avatar
The89Blazer is on a distinguished road
Ahh...thanks for the wiring diagrams, ill print them out. Here is the kicker, i just looked at the passenger side door courtesy light switch...i pulled it out from the side dash panel, and there isn't a wiring harness there??? Im thinking maybe when that chop shop did the heater core they didn't bother reconnecting it? And i cant' seem to find the harness....or if there had been one there..why would there be a switch with no harness? Im hoping it didn't get lose behind the dash and screwed there and then shorted...b/c that would be the only culprit.
Old Dec 12, 2010 | 07:19 PM
The front door switches are in the latch inside the door. GM just put the old switch there to mess with us.
Old Dec 12, 2010 | 07:46 PM
Thanks for all your help, when i slam the door hard enough, the relay decides to work...ill get into the door and go from there i guess..nothing like an electrical issue..unless its in the harness that continues to travel through out the truck, im not sure..i wiggled wires under the dash of the passenger side, and the buzzing didn't go off until i slammed the passenger door, then the over head light turned on, buzzing went away..everything worked. Why is there a plug switch on the driverside door and not the passenger side door?
KopterDr
May 15, 2021 02:25 PM
cameo_cruiser
Nov 14, 2011 05:34 PM
Blazers.B.Kewl
Mar 28, 2010 01:54 PM
corvetteman
Jan 7, 2010 02:56 PM
slamb478
Apr 29, 2008 03:29 PM
