Electrical Help!
Old Apr 17, 2010 | 11:44 AM
Tony's 02 Blazer's Avatar
Tony's 02 Blazer is on a distinguished road
Angry Electrical Help!
I have an 02 ls, and last week i went to start my truck at night, and the compass/thermometer and my gauge backlighting wont work! Whats wierd is that the compass/thermometer works during the day, but once the sensor senses that its dark out, it stops working. i just replaced the sensor, and its still doing the same. HVAC lights wont come on either at night.
So my question is... is there a fuse or relay that controls all these lights to come on when the senses switches to "night"? Any help would be great, because this is really frustrating me.
Old Apr 18, 2010 | 12:20 AM
Do the dash lights work properly? Have you tried turning up the dash brightness?
Old Apr 18, 2010 | 12:38 AM
Yeah, all the other dash lights (turn signal, low fuel, etc.) work fine, except for the backlighting. and the compass will display everything in the daytime.
What relay would that be wired to?
Old Apr 18, 2010 | 12:40 AM
No, I am not talking about the signals or other information lights, but the illumination lights, the back-lighting itself.
This does not go through a relay. Just the ILLUM fuse. Check that, but also check the little dial on the headlight switch to make sure it isn't all the way turned off.
Old Apr 18, 2010 | 12:42 AM
Ive checked that fuse, and it was fine, then i replaced just to make sure. the dial isnt off either. Ive checked the bulbs on the backlighting, and theyre fine too.
Old Apr 18, 2010 | 12:43 AM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Look at the underhood fuse block for the (park LP fuse) it will be a 20A fuse right by the HVAC 30A fuse, bet it is Blown check it out and let me No ? T.J.
Old Apr 18, 2010 | 12:48 AM
Yep, the LP fuse was going to be my next suggestion since that feeds the ILLUM fuse.
Old Apr 18, 2010 | 12:52 AM
Nope, it wasnt the fuse TJ
Old Apr 18, 2010 | 01:56 AM
Sounds like you either have a wiring problem, or a problem with the dimmer side of the headlight switch.
Old Apr 18, 2010 | 12:01 PM
Man I was hoping it was the Fuse. What have you done lately any upgrades? Radio, Amps? I quess I lost the Bet HUH,Sucks
