Electrical horror show
Old Jun 9, 2018 | 03:58 PM
  #41
Tajohns34's Avatar
So I couldn't find a damaged wire anywhere. However, I noticed that my carpet was wet by the driver's door (I need hinge pins). I removed the driver's seat and noticed that the harness ran under the carpet and was soaked. I hooked the battery back up and wiggled the wire and the back hatch glass started clicking and then smoke. I have never pulled a negative battery terminal so fast.
This...
I guess I will be spending some time with a hair dryer and doing some wiring repair tomorrow.
Old Jun 9, 2018 | 04:06 PM
  #42
Rusty Nuts's Avatar
Awesome! You found it. Not awesome it's that. When I repaired mine I staggered the connections so it wouldn't ball up.
Old Jun 9, 2018 | 04:23 PM
  #43
GeorgeLG's Avatar
There it is, nice work. Let us know if anything remains after you fix those wires.
George
Old Jun 9, 2018 | 08:12 PM
  #44
Tajohns34's Avatar
It was supposed to rain all weekend. It was beautiful today, hopefully tomorrow is more of the same.
Old Jun 10, 2018 | 02:55 PM
  #45
Tajohns34's Avatar
The weather did not cooperate today. I did isolate the good wires from the damaged ones and cut out that bad sections. I also cleaned the floor and painted it with 2 coats of hammer finish. That is about all the time I had between rain storms. There are 2 orange wires that melted apart, and I have no idea what the difference between the 2 is. Anyway, pictures.
Old Jun 10, 2018 | 03:42 PM
  #46
Mike.308's Avatar
That looks brutal
Good thing is You have traced down the problem. Isolate the orange ones and report what is not working.
Old Jun 10, 2018 | 06:18 PM
  #47
Tajohns34's Avatar
It isn't just the orange ones. There are 2 black with white lines, 2 orange ones, 2 light green ones, and 2 light blue ones. Also, I am surprised these didn't get burnt worse than this. Some of these wires are so thin that I can't keep the smallest butt connectors on them. I might have to solder them instead.
I got the big orange wire connected (it looks like it is about 12 gauge) and then Nature was all like "you aren't wet enough". I don't know why they look different, but they are the same color orange. The middle is yellow.
Old Jun 11, 2018 | 01:53 AM
  #48
Mike.308's Avatar
A mental shortcut. I mean to rework the insulation on the ones You can and isolate the ones that melted apart and check what isn't working. Then, we can lookup the wirings of a not-functioning devices and identify missing connections by a wire color.
P.S. I'd personally go for the shrinking tubes & soldering iron. They might be flatter than connectors.
Old Jun 11, 2018 | 05:12 AM
  #49
Tajohns34's Avatar
I may go back and try soldering later. At this point i nust want to make sure everything works first.
Old Jun 11, 2018 | 07:36 PM
  #50
GeorgeLG's Avatar
Once you get all your connections verified, solder and adhesive shrink wrap is the way to go.
George
