Electrical Question - Quick Help.
Old Aug 6, 2009 | 01:47 PM
upblazer95's Avatar
upblazer95 is an unknown quantity at this point
Post Electrical Question - Quick Help.
Hey Guys,
Just a quick question, I am burning through these Fuel Pump Relays like a kid in a candy store. Well its only one pin on the relay that is getting chard every time. If you look at the Relay its Pin 87 which I believe switches between The Battery Power/ECM and Pump as well as the Prime Connector. Any reason you guys can think these things would be burning up like this, and why on just that one pin?
Thanks,
Joe
Old Aug 6, 2009 | 02:49 PM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
Default Burnt relay terminal pin
The mating socket may have a loose 'female' connector. A loose connector will cause overheating (that's how aluminum wiring burned houses down and many rear window defoggers' terminals get cooked and melted).
Old Aug 6, 2009 | 03:25 PM
upblazer95's Avatar
I will go outside and see if that might be the problem. Thanks...
Old Aug 6, 2009 | 07:56 PM
You may have to replace the receptacle that the relay mounts into. As stated above, the corresponding terminal is either loose or corroded. You may be able to push the terminal out of the block and clean the contact area, tighten up the fit and reinstall it. You may need to get some terminal release tools to make the job easier.
JoSHN
Sep 14, 2012 04:56 PM
vetteman61
Jan 12, 2007 04:32 AM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
