Emisions rejected
Old Feb 14, 2011 | 03:15 PM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default Emisions rejected
On my 96 blazer I had the emissions tested,
The sheet said it was rejected because:
On-Board Computer:
Unable to test the vehicle-following
readiness monitors were not set:
Catalyst
Evaporative system
EGR system
Any Ideas on this one??
I did a search but found nothing.
Old Feb 14, 2011 | 03:24 PM
rriddle3's Avatar
Was the engine fully warmed to operating temperature and driven a few miles prior to the testing?
Old Feb 14, 2011 | 03:44 PM
Beckyj636's Avatar
Yes it was
Old Feb 14, 2011 | 06:03 PM
AJBert's Avatar
Just a thought, but if those "codes" were deleted from the PCM during a tune, would the DMV's scanner pick up on it?
Something I've always wondered about.
Old Feb 16, 2011 | 12:45 PM
Beckyj636's Avatar
There were no codes the battery was disconnected.,
Old Mar 15, 2011 | 09:55 AM
Beckyj636's Avatar
OK after 1 month of driving atleast 200 miles It still fails emissions.
Here is what the scanner told me:
Catalyst
evap
egr
readiness sensors not set
catalyst mon inc
htd catalyst n/a
sec air sys n/a
evap system mon inc
a/c refis mon n/a
egr system mon inc
Please help this is driving me nuts. I only have one more month for a temporary plate.
Thank you so much..
Old Mar 15, 2011 | 06:12 PM
Beckyj636's Avatar
Well i am changing the thermostat. When the engine is warm the gauge reads 2 lines above the 100 mark.
Old Mar 15, 2011 | 07:02 PM
motate's Avatar
motate is on a distinguished road
Default Emissions Rejected
I have a 1998 blazer with the exact same problem. First off, you screwed up when you disconnected the battery. By disconnecting your battery you 'shut down' the computer. You now have to run the car for a few HUNDRED miles for the computer to reset itself. NEVER DISCONNECT THE BATTERY!!!! There's nothing really wrong with the car. The computer has to reset itself. This is the second time for me. I now have over two hundred miles on the car but will NOT get it re-inspected until I add another two hundred. Also, do highway AND city driving. The computer WILL eventually reset it but it will do so when it's ready. I have a company car so don't drive the blazer that often. By the time vacation rolls around and I get in the car, the battery's dead. The mechanic that checked it could not understand why the car does this but it does. Also, make sure you have the correct amount of oil in the crankcase. Keep driving for at least 400 miles. Take it back to the inspection station. It SHOULD pass. Let me know how you come out. Any other suggestions are welcome but this is what has worked for ME. Good luck.
1998 Chevy Blazer
116 thousand miles
Last edited by motate; Mar 15, 2011 at 07:04 PM. Reason: Adding vehicle year and mileage
Old Mar 15, 2011 | 07:29 PM
01BlackBeauty's Avatar
01BlackBeauty is on a distinguished road
I may be wrong, but IIRC I don't think it has to do with the amount of miles you put on the vehicle, it has to do with the number of start up/shut down cycles the engine goes through. Each cycle requires that the engine be cold and brought up to full operating temperature.
Old Mar 15, 2011 | 08:20 PM
Beckyj636's Avatar
Well I changed the thermostat and now the temp is near the 210 mark. .
I will test it again Thursday when there open.
Can the engine not getting hot enough cause poor gas mileage ??
