engine bogs out
alright thanks for all your help!! your the best
to marrow im going to his house and we will try and get that o2 sensor looked at and hpefully get a new one in to see
one more thing how can one little sensor like the o2 make the truck bog out when you hit the gas hard but if u ez it ever so lightly you can still drive it but not pass 1889 rpm oh yea and why 4 o2 sensors?
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
The O2 sensor is the main sensor in determining the fuel injector pulse width. If it is lazy, slowly creeping up on the throttle can mask the issue, but quick changes in throttle position can cause the delay.
Another thing that may be worth checking is the TPS (throttle position sensor). It should read ~0.5V (key-on, engine-off, throttle closed) and ~4.5V (key-on, engine-off, throttle fully open). But an O2 sensor code can definitely cause the symptoms you are experiencing.
UPDATE
ok we went and got a new o2 sensor installed it, then we erased codes and went for a drive and still same problem but this time we got no mil light so i get no codes
as i was changing it i noticed an exhaust leak coming from the exhaust manifold to the y pipe like right between where it bolts together i called the parts store they dont have a gastkit for it hmmm i don't think that would cause the bogging
i guess im at square 1 again![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
alright took it to the store and i got my mil back on now now i get codes
p0151x2
and p0131, but i just changed that o2 sensor with a new one
and i got a new one p0137
also i noticed when we try to go full throttle there is black residue on the ground where the tail pipe is
update
ok i also went uder the truck to bang on the cat i here rattleing does this mean my cat is gone would a bad cat cause this proplem also ?
p0151x2
update
Last edited by swartlkk; 02-07-2010 at 02:44 PM. Reason: Combining Consecutive Posts - Please use the EDIT function to add additional information to your post if another member has yet to reply. Consecutive Posting is prohibited by the rules of the forum.
Also like i said i went under the trunk, and banged on the cat. I hear rattling like there is screws or marbles inside , there is plenty of exhaust from tail pipe (very cold out ) so it cant be clogged ?
I suppose it is possible for a clogged cat to blow out the donut... You could remove the B1S2 O2 sensor and drive it around (after fixing the exhaust leak) and see if that somewhat cures the problem.
update:
went to the shop to day got the to take off the cat . man was that thing ever broken chunks everywhere,got new one put on trucks like 50 % better now i get no more codes no mil but the proplem is that i cant get Wide open throttle soon as i try to floor it it bogs down
new wires
new plugs
new dist cap
new fuel filter
new cat
changed oil
how can i diagnose the problem now ?
my buddy said it might be the passing gear on the tranny or the solenoid?
new wires
new plugs
new dist cap
new fuel filter
new cat
changed oil
Back to post #2, have you checked fuel pressure and leakdown?
https://blazerforum.com/forum/tech-articles-diy-29/96-fuel-system-diagnosis-23038/
and thanks for posting that it was very helpfull
