Engine Code P0446
Old Feb 7, 2009 | 04:35 PM
truesmack's Avatar
truesmack is an unknown quantity at this point
Default Engine Code P0446
I have been getting a couple codes on my blazer, code p0440, which is the air-smog pump, generally I clear the code and it goes away for a couple weeks or so then it will come back, right now that code isn't there, any suggestions, replace or just clean it up and see if any water in the pump, where is it located? I was told up front by the oil filter on passenger side, does this make sense.
Also, just today, got a p0446 code for the first time, evap code, vent control malfunction. Where should I start with this one? Is it something to do with the vent for the gas system under the truck by the tank? All you help is greatly appreciated, as always.
2001 Blazer, 4dr, 4x4
Old Feb 7, 2009 | 06:43 PM
rriddle3's Avatar
Default RE: Engine Code P0446
I just used 'Search' for 'P0446' and voila!
P0446 EXPLAINED
The air pump is under the bumper on the right hand side.
Brianator99
Oct 19, 2012 10:39 PM
KevinZR2
Mar 22, 2012 06:34 PM
spongebobmac
May 1, 2011 08:50 PM
Arepok
Jan 28, 2011 12:36 PM
jpmccr
May 6, 2009 07:11 AM
