vaccum problems
Old Feb 6, 2009 | 07:48 PM
keithduke65's Avatar
keithduke65 is an unknown quantity at this point
Default vaccum problems
hose going to motor was leaking, fixed this, hooked all hoses back up,unhooked battery to turn off engine light, now when i go in 4x4 it seems to slip and go in and out of 4x4?
Old Feb 7, 2009 | 02:11 AM
blknwhtblaze's Avatar
blknwhtblaze is an unknown quantity at this point
Default RE: vaccum problems
check all of your vacuum lines there are some back of engine bay driver side connected little ball thing on you hood but there are several 4wheel vacuum lines there check all the fittings they tend to collect dirt and get clogged check those out then take your passenger headlight out and your diaphragm is under the battery and when you push the button for the 4wheel the diaphragm will engage and will lock your front end in but if you have a leak or weak pressure it wont fully engage so it will tend to slip check those out and let me know.
Old Feb 7, 2009 | 11:07 AM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
I Concur...
just as an FYI you would typically don't ask stuff like this in the welcome section.
Old Feb 7, 2009 | 01:31 PM
*Moving to 2nd Gen Tech*
Old Feb 7, 2009 | 07:24 PM
what the **** do you mean?!
keithduke65
Feb 7, 2009 01:31 PM
shanes
May 5, 2006 01:23 PM
djestes
Jan 2, 2006 01:29 AM
ron36535
Dec 28, 2005 04:05 PM
BUDWZR8
Dec 21, 2005 11:31 PM
