engine light
Old Nov 24, 2007 | 04:21 PM
Shaggz's Avatar
Shaggz is an unknown quantity at this point
Default engine light
my engine light comes on and off as it pleases lol, i put the scanner on and it said their isa misfire incylinder 3 then it went off after i changed plugs and wires then it came back on and said misfire in cylinder 6,the wire came off, put it back on and now the engine light goes on for an hour or two then turns off and back an forth, it also shakes bad when im sittin at a light or idiling, any suggestions would be great. im new to blazers, i drive a 99' blazer trailblazer ed. 4dr. auto, and dont know too much bout them
Old Nov 24, 2007 | 08:07 PM
Default RE: engine light
When was the last time you did a full tune up on the engine? Random misfires are typically tied to worn ignition components (cap/rotor and/or wires).
I would replace the plugs, wires, cap & rotor as a starting point. Maybe clean the MAF, EGR, and throttle body (including the IAC valve & bore on the TB).
damageinc98
Jul 12, 2010 10:47 PM
zoniah
Jun 2, 2008 08:45 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
