Engine Miss during rainy conditions
Old Mar 28, 2008 | 07:58 PM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default Engine Miss during rainy conditions
My wife's 98 Bravada 4.3L delvelopes a engine misfire during rainy weather. I figure it needs new plug wires. Anyone else have an opinion?
Thanks!
Old Mar 28, 2008 | 08:47 PM
rriddle3's Avatar
Default RE: Engine Miss during rainy conditions
Might want to replace the distributor cap and rotor and make sure there's no moisture getting inside it. Check all the ignition wire connections, too.
Old Mar 28, 2008 | 09:27 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
If you changed the plugs recently and reused the wires did you put boot lube or whatever you find it called on the plugs. If not the stock boot lube in the wires is probably non-existant now and might be allowing mostiure to enter the plug wire.
crookedbowtie
Jan 21, 2013 12:23 PM
Cidium
May 11, 2011 03:50 PM
Imado
Dec 17, 2010 11:13 PM
22mr2
May 23, 2010 12:58 AM
guitarzan
Mar 4, 2009 09:25 PM
