Engine overheating, no heat inside truck
Old Feb 12, 2012 | 10:57 AM
sunnyblueskies's Avatar
sunnyblueskies is on a distinguished road
Default Engine overheating, no heat inside truck
2000 Jimmy Sport
Hey guys,
We're having problems again.
This time it's the cooling system.
Engine overheated (in -20C ),
heater blew cold air only,
rad fan runs,
no major leaks, except out of the weeping hose of the reservoir,
yes there is fluid in the reservoir
belt starts to smell after running for a few min. only, smokes if you leave it run too long
First thought that comes to mind is the water pump, could be thermostat, but then the belt wouldn't get hot.
Before I go out and buy a waterpump I would like to make sure that it isn't something else and I just wasted money on a waterpump.
Can you guys help me out with steps I should take, or things that I should check in order to find the true problem??
Thanks.
Old Feb 12, 2012 | 11:09 AM
warthogdriver's Avatar
If belt is burning up i would think somehting def is not turning as freely as it should. Also no heat implies that there is nothing moving th coolant...i.e. no pressure ...no waterpump doing its job.
I would say pump...overheating can happen but it shouldnt have anything to do with the belt burning up...the two combined still say pump to me.
Old Feb 12, 2012 | 11:15 AM
Yeah the belt gives it away I suppose.
You guys are just so much more vehicle savy as me I thought I better double check if there isn't something else that I should look at before.
What's the best way to take the pump out?
Or where is the best thread that describes it?
Thanks.
Old Feb 12, 2012 | 11:42 AM
spittybays
Guest
Posts: n/a
Old Feb 12, 2012 | 11:49 AM
Awesome!!!!!
Thanks Spittbays........
I'll let you guys know how it worked out..........in a couple days!
Old Apr 6, 2012 | 02:14 PM
Scott A Timmreck's Avatar
Scott A Timmreck is on a distinguished road
Default thermostat
i am pretty sure my thermostat is not opening but i am not sure where on my v-tec 95 jimmy motor, i beleive it is a stock motor for that year, cant figure out how to get to it without moving belts n stuff???
Old Apr 6, 2012 | 04:31 PM
Thogert's Avatar
If you need to, just remove the belt. It's not hard.
Oh and by the way.... It's a VORTEC, v-tec's go in hondas.
Old Apr 7, 2012 | 09:24 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Your truck overheating is directly related to the burning rubber smell. The water pump is locked up and not spinning, causing the truck to overheat and the belt to slide on the pulley instead of turning it, which is causing the burning rubber smell.
Stop driving.
Brewmyown
29
Oct 27, 2014 10:50 AM
SnowRemorse
Sep 8, 2008 07:30 PM
S10Blazer
Aug 10, 2008 11:51 PM
jagblazer01
Nov 13, 2006 04:29 PM
Dwarf415
Jun 16, 2006 01:23 PM
