engine shakes at idle
Old Jun 29, 2010 | 10:29 AM
rasputinlv's Avatar
rasputinlv is on a distinguished road
Default engine shakes at idle
Hi guys.
My engine shakes at idle and it keeps shaking with no power until it's 30mh.
I fixed coolant leak, it was thermostat. Could it be still bad intake gasket?
or I need to look at distrubiter?
thanks an advance.
Old Jun 29, 2010 | 10:33 AM
Vehicle info?
Old Jun 29, 2010 | 11:28 AM
rasputinlv's Avatar
OPS, it's Blazer 98, automatic, 2W, 108K on it.
it was code on it, but it went away, I wonder if autozone can still read it.
thanks guys.
Old Jun 29, 2010 | 11:33 AM
The code would be quite helpful.
Old Jul 4, 2010 | 02:29 AM
rasputinlv's Avatar
Finally got a code:P1345
Thanks
Old Jul 4, 2010 | 06:48 AM
P1345 - Crankshaft Position [CKP] Camshaft Position [CMP] Correlation
Have you replaced any of the following; distributor, cam position sensor (CMP), crankshaft position sensor (CKP), or timing set?
When was the last time a tune up was performed? EGR valve cleaned? MAF sensor cleaned? Throttle body cleaned?
Old Jul 4, 2010 | 01:08 PM
rasputinlv's Avatar
Nothing was replaced on the car, neither done, no tune up since I got the car when it was 47K on it.
I'm going to do all that cleaning first, before getting another distributor.
Thanks for help.
Old Sep 5, 2010 | 02:10 PM
rasputinlv's Avatar
Guys, what brand distributor shell I get? Is Delphi OK?
What does it mean with out module, is that what I need for Blazer 98?
Thanks an advance.
Old Sep 5, 2010 | 02:16 PM
Delphi is good. Without module likely means that it doesn't come with the CMP sensor.
Have you tried to have a crankshaft variation relearn procedure done by the dealer (or a shop equiped with the proper tools to perform the procedure)?
Old Sep 5, 2010 | 02:30 PM
rasputinlv's Avatar
No, I haven't. Should I?
Thank you.
