Engine stalls while driving. Intermittent problem.
Old Jun 7, 2013 | 05:42 PM
S.Hafsmo's Avatar
S.Hafsmo is on a distinguished road
Default Engine stalls while driving. Intermittent problem.
Are there any issues that could cause something that would appear as shutting the ignition off/on while driving?
To me it sounds like improper grounding/battery connection, or a broken wire to an ignition module or similar. Anyone got any experiences like that?
The engine just cut while driving, and the gauges/lights in the dash flashed like they do when you turn the ignition on in the morning. First time this happened was after hitting a bump in the road. Engine starts right up afterwords.
It's a 98' 4wd S10 Blazer
Old Jun 7, 2013 | 05:54 PM
Could be an ignition switch problem. VERY common on 1997 as the switch was unique to that year, but it can happen to any of them. https://blazerforum.com/forum/articl...-switch-33465/
Old Jun 7, 2013 | 07:55 PM
S.Hafsmo's Avatar
Thanks, Just found a new one on e-bay, so we'll see if it does the trick.
Old Nov 14, 2013 | 03:38 PM
S.Hafsmo's Avatar
Replaced the ignition switch, and the car seems to be working perfectly fine. Even the windshield wipers, which sometimes seemingly had a life of its own, are now behaving according to switch position.
Might also mention that when the car stalled, and was refusing to start, one could hear sort of a slow whirring noise coming from below the drivers seat (assuming it was the fuel pump). This noise dissappeared after the ignition switch replacement.
doccheese
Dec 12, 2014 03:43 PM
Zjoseph
May 29, 2010 12:44 AM
c0a8l0v6i8n9
38
Jan 15, 2010 07:18 PM
joeazevedoiii
Nov 23, 2007 05:35 PM
koenigk
Jul 24, 2007 03:17 AM
