Engine Temps?
This is on the front of the engine near the center of the block there is a black pipe that is the thermostat housing...
[IMG]local://upfiles/1127/F8B7625A6ED44906A37EDE01CA48B2DF.gif[/IMG]
[IMG]local://upfiles/1127/CE314D893F82468F886DF09286EBED6B.gif[/IMG]
well u will defininitly need a thermostat gasket and maybe some teflon tape around the senders threads. i also put some high temp rtv sealant/gasket on the termos housing for added security, just make sure u wait for the rtv to dry before driving. u can run the truckto check for leaks but u dont want get the rtv in the intake. and on the 92 tbi the thermo is on the opposite end of the intake. what i mean is the egr is in the back while the thermo is up front. follow the top hose from the rad to the thermo housing. also i have two wires grounded to the housing make sure they arre not stuck to the housing if u have these wires and then when tightening make sure u hold on to the wires so they dont turn with the bolt a break.
Ok, so basicly follow the radiator hose from the top of the radiator to this thermo housing. So then I drain the radiator, then take the hose off the thermo housing and the thermostat sensor is inside that? That is what I need to replace?
