Engine Temps?
Old Dec 3, 2006 | 09:05 PM
20Blazer00's Avatar
Default RE: Engine Temps?
This is on the front of the engine near the center of the block there is a black pipe that is the thermostat housing...
[IMG]local://upfiles/1127/F8B7625A6ED44906A37EDE01CA48B2DF.gif[/IMG]
[IMG]local://upfiles/1127/CE314D893F82468F886DF09286EBED6B.gif[/IMG]
Old Dec 3, 2006 | 10:12 PM
FImports's Avatar
FImports is an unknown quantity at this point
is that by the egr vaule.i have a 92 s-10 blazer 4.3
Old Dec 3, 2006 | 10:25 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Ok so what do I need to buy to replace it? Any gasgets involved when I replace that? Any other sensors I should replace that may contribute to this inaccurate temp reading.
Old Dec 4, 2006 | 11:00 AM
rooster's Avatar
rooster is an unknown quantity at this point
well u will defininitly need a thermostat gasket and maybe some teflon tape around the senders threads. i also put some high temp rtv sealant/gasket on the termos housing for added security, just make sure u wait for the rtv to dry before driving. u can run the truckto check for leaks but u dont want get the rtv in the intake. and on the 92 tbi the thermo is on the opposite end of the intake. what i mean is the egr is in the back while the thermo is up front. follow the top hose from the rad to the thermo housing. also i have two wires grounded to the housing make sure they arre not stuck to the housing if u have these wires and then when tightening make sure u hold on to the wires so they dont turn with the bolt a break.
Old Dec 4, 2006 | 02:32 PM
AutomagicLS1's Avatar
AutomagicLS1 is an unknown quantity at this point
Interesting mine is running (cooler than normal) I may replace my Tstat as well
Old Dec 4, 2006 | 05:12 PM
Ok, so basicly follow the radiator hose from the top of the radiator to this thermo housing. So then I drain the radiator, then take the hose off the thermo housing and the thermostat sensor is inside that? That is what I need to replace?
Old Dec 4, 2006 | 10:25 PM
rooster's Avatar
no the tstat is in the housing, the sender should be imediatly to the left of the tstat/housing, at least it is on the 92 4.3 tbi
Old Dec 4, 2006 | 10:44 PM
Ohh I thought you guys said it was inside the engine where the radiator hose connects? I cannot pinpoint where this is. I think I know where it is, but you guys say it is not that.
Old Dec 5, 2006 | 04:37 PM
Can anyone help me pinpoint this thermostat sensor that I need to replace. Also whats the real name for it so I can go find the part.
Old Dec 5, 2006 | 09:57 PM
rooster's Avatar
coolant temperature sender is the name and i think its in the cylinder head on the drivers side on a 2000, just above the steering column near the middle plug.
