Error Codes P0108, P0121 and P0122
Old Apr 6, 2011 | 02:16 PM
HoleinOne350's Avatar
HoleinOne350 is on a distinguished road
Default Error Codes P0108, P0121 and P0122
Hi All,
My check engine light recently came on (1998 Chevy Blazer) and I plugged in my scanner and got the following codes P0108, P0121 and P0122. Not sure what I have to do to fix these and I believe they are related. Thanks for any help I can get.
Old Apr 6, 2011 | 02:45 PM
P0108 - Manifold Absolute Pressure [MAP] Sensor Circuit High Voltage
P0121 - Throttle Position Sensor Circuit Range/Performance
P0122 - Throttle Position Sensor Circuit Low Voltage
A problem with the +5V reference from the PCM or either of these sensors could cause all of the codes that you are getting. The TPS sensor should output ~0.5V at closed throttle and ~4.5V at wide open throttle and should be a smooth transition between those values.
The MAP sensor outputs a voltage in response to the vacuum level in the intake. I have posted the normal atmospheric voltage outputs that should be expected in other threads and a search for "map+altitude" should turn that information up.
Old Apr 6, 2011 | 10:40 PM
DKSDAD's Avatar
Welcome from New York.
Silver00LT
Nov 17, 2012 05:42 PM
bc4059
Aug 4, 2010 08:36 PM
taguy94
Sep 29, 2009 12:27 PM
bbunn1
Sep 1, 2006 12:55 AM
