Errors
Old May 24, 2010 | 11:42 AM
blazi99's Avatar
blazi99 is on a distinguished road
Default Errors
Hello. I have errors :
P0102 Mass Air Flow (MAF) Circuit Low Input
P0132 O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
What should I check?
What is broken?
Can Oxygen can be when I hit the water.
Thank you for your interest in my problem.
Old May 24, 2010 | 11:51 AM
Have a read through these and look for common points in the diagnosis:
P0102 - Mass Air Flow Sensor Circuit Low Frequency
P0133 - HO2S Slow Response Bank 1 Sensor 1
P0143 - HO2S Circuit Low Voltage Bank 1 Sensor 3
I don't have the time to pull together P0132, but you should get the gist of the code by reading through P0131:
P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1
Old Jun 3, 2010 | 06:53 AM
blazi99's Avatar
I put the used mass air flow sensor, I changed to the new spark plug wires, and spark plugs, everything was fine for 2 days after car began to smoke a lot of fuel and got new errors P0171, P0300, P1121 and P1133 I have a little dig and see
Old Jun 3, 2010 | 11:54 AM
UrlorJkron
Apr 13, 2010 06:41 AM
frankmackie
Mar 8, 2007 08:46 PM
