EVAP Fuel Vent help
Old Sep 19, 2008 | 01:54 PM
skyblazer's Avatar
skyblazer is an unknown quantity at this point
Default EVAP Fuel Vent help
Spec:
96 Blazer LT 4.3L v6 4dr
Ok here is the problem i am having:
I ran into sending the truck out to replace my gas tank and with thatreplace the sending unit/pump with a new Delphi unit.
now igot the vehicle back and it came up with a P0440 EVAPsystem (found code description in my haynes manual)
I sent it to another mechanic closer by and found out that the fuel vent on the tank had snapped and needs to be replaced
My question:
Can anyone describe in word or even pics of what the part looks like and how to remove/install a new one? (searched the haynes manual and came up with nothing )
Help be very greatful
Thnaks all
Skyblazer
Old Sep 19, 2008 | 06:18 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: EVAP Fuel Vent help
on your 96 you should have 2 of them in each corner of the tank. If this all happened since the tank was dropped my guess would be that one or both of these vent valves were broke during the tank drop-although this may be tough to prove and it also depends upon the 'deal' you got from them for doing the job. Anywho..tank will have to be dropped again-you'll probably visually see which(or both) valve is the issue. They turn counterclockwise a half a turn or so and pop out Install is the reverse. Good luck. JP[X(]
Old Sep 20, 2008 | 02:26 PM
hernandez3674's Avatar
hernandez3674 is an unknown quantity at this point
Just like Peru said.. i paid about $20 bucks at my local dealer and it was in stock. The dorman # 911001 but one u get it off the GM # is stamped on it...
[IMG]local://upfiles/8336/DBF93DD97B3040DE941A20C36C2DB0A0.jpg[/IMG]
Old Oct 4, 2008 | 10:42 AM
skyblazer's Avatar
great! thanks alot guys... i was able to find the one vent that snapped and was able to get it done thanks for the info
PS: also replaced the hose since i was under there since it was quite weathered
Old Oct 4, 2008 | 01:56 PM
you're welcome!jp[:-]
Old Jun 7, 2009 | 01:42 AM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default valve
I only have one front driver side. I have the same code. I have Alldata for this truck and it shows the canister vent valve.
4.3 L
However I don't see it Any ideas where it hiding
In the pick it is #1 that i seek.
Old Aug 25, 2009 | 09:30 PM
f10ski's Avatar
f10ski is on a distinguished road
i just took mine appart and cleaned it out--- hope it worked. anywho, mine (2003) i actually located in the back of the vehicle, above the tank. i had to drop the plastic tank shield to make it easier to get at with an easy reach just above the rear axle. basically, unplug wiring, disconnect the plastic vent tube and carefully slide the whole assembly out sideways towards the drivers side back tire. from your schematic above, it seems like the same thing as mine. good luck.
hilsenteger
Mar 22, 2010 09:18 AM
turretman
Jan 21, 2009 06:19 AM
Havsurf
May 22, 2008 07:32 PM
ned4spd8874
Apr 7, 2008 02:13 PM
wdonovan
Jun 13, 2007 11:24 AM
