evap stuff
Old Oct 24, 2009 | 07:30 PM
jigger's Avatar
jigger is on a distinguished road
Default evap stuff
trying to pass calif smog. emissions are great but--evap system is leaking, put new lines and tested between canister and purge valve (in engine compartment) tests good. smog tech says its leaking around the top of the tank. i lowered the tank and removed the rubber lines and they look good.also should there be some kind of seal around what looks like the vent outlet? i'm stumped! THIS IS A 95 S-10 4WD V-6 LS MODEL ANY--IDEAS WILL HELP
Old Oct 24, 2009 | 08:56 PM
jigger's Avatar
I ALSO PUT ABOUT 15lbs OF AIR TO THE TANK AND CAN HEAR LEAKING BUT IT SOUNDS LIKE IT IS FOWARD OF THE FUEL PUMP BUNG. WHAT IS ON TOP OF THE TANK? I DON' HAVE IT ALL THE WAY DOWN. HELP HELP!
Old Oct 25, 2009 | 08:06 AM
Please have patience.
I would be careful with putting that much pressure into a system that typically is under vacuum. You may cause more problems than you solve.
With some pressure in the system, trace along all of the lines with a mechanics stethoscope (or a modified medical stethoscope if you have one). This will help you locate the leak.
If you think the leak is on top of the tank, you will have to drop it down until you can see what is going on up there at the very least.
Old Oct 25, 2009 | 10:15 AM
jigger's Avatar
thanks. ill give it a try.
Old Oct 25, 2009 | 01:17 PM
jigger's Avatar
Hey i think i found it. The front vent is broken where the vac hose connects.now where can i find a replacement?
swartlkk
Jul 15, 2011 01:47 PM
JudOWNED
Jan 26, 2010 09:18 AM
swartlkk
Oct 29, 2007 11:24 AM
blazinblack
Oct 3, 2007 12:10 PM
wdonovan
Jun 13, 2007 11:24 AM
