Yes to all of the above. Stalls at idle.i still getting the code and I only feel the missfires at idle. I can see the misfires only at idle. I don't see any misfires when I'm driving. An example is after driving I'll pull into a parking spot and before I can put in into park it will stall if I don't have my foot on the gas peddle.
You have misfires and a code that there is a communication problem between the PCM and the ICM, this needs to be resolved. Perhaps the attached can help.
I'm dog sitting for a friend for the next 2 weeks so i won't be able to do anything until my friend comes back from Europe. But as soon as I'm free again I'll take a look. I'm probably gonna have some questions. Thank you very much for taking the time to send me this information 👍
I'm starting to test and I'm on step 3. Probe the ic timing circuit is that the B White or D white/black ? I'm assuming it's B because D goes to the coil ? Also should I pull the fuel pump relay when I do this test so I'm not pumping fuel into the engine when I'm testing?
It points to the icm. Just ordered a new one from Amazon and will replace it tomorrow. I'll let you know how it goes. Thanks again for all your help George 😊
I just got the icm installed it and P0351 is gone. Lesson learned. Dont buy Chinese ICM's ! But now i have P0300 Multiple misfires. Im gonna spray the wires and see if i see anything. Im gonna try another coil i have. I might have to buy another one.Im not sure what else i can do but if you have any suggestions it would be much appreciated. Thanks for all the help getting me past the p0351 😉
