Failed Emissions - Items not ready.
Old Jun 4, 2010 | 10:33 AM
dannyek7's Avatar
dannyek7 is on a distinguished road
Default Failed Emissions - Items not ready.
Recently took my blazer into the shop. Had a bad IAC pump. Was throwing the notorious secondary air injection fault error before I had the repair. There was a blown fuse in the fuse box above the secondary air pump (I replaced the fuse before the repair). I got the truck back a week ago, and the check engine light was off.
I drove around 400 miles since I've had the truck, in all conditions. Yesterday when I took it in for inspection, I failed due to no reading coming from the secondary air pump and the catalytic converter.
Anyone have any suggestions?
Old Jun 4, 2010 | 10:40 AM
1998MSO's Avatar
1998MSO is on a distinguished road
What year, make, model, mileage etc.....?
Old Jun 4, 2010 | 12:34 PM
dannyek7's Avatar
2001 s10 blazer 4wd 5spd 104k
Old Jun 4, 2010 | 07:53 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
When you replaced the pump any chance you reversed the the two vacuum hoses on the switch on the pump? I dunno if there's a check valve in there and it would only let it work properly in one direction? Check the IGN E fuse in the underhood fuseblock (powers the relay coil for the pump). I assume you replaced the 30A maxifuse, did you also check the smaller 10A fuse on that block (powers the vacuum solenoid switch on the pump)?
avonderlinde
Mar 8, 2015 04:05 AM
edkimdavey
Aug 8, 2009 07:57 PM
dyeraudio
Mar 7, 2009 07:15 PM
Spartan66
Jul 3, 2008 12:11 PM
Blahman20
Apr 21, 2007 07:06 AM
