Fan clutch questions
Old Nov 3, 2012 | 10:15 AM
newguy's Avatar
Default Fan clutch questions
Figured out my cold truck howl is the fan clutch. Is this normal, if so it sucks. engine off the fan spins but with some resistance. How do they work normally
Old Nov 3, 2012 | 03:20 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Re fan clutch
The clutch works as follow when your engine is warm it will engage and make your fan blade spin faster.when its cold it doesnt engage and your fan blade will spin slower till the engine warms.My suggestion is eleminate it and go direct drive with high performance flex fan or ditch the fan altogether and replace it with an electric fan.This will give your engine more power and less drag.Im going to eventualy do this with my Jimmy.
Old Nov 3, 2012 | 03:30 PM
spittybays
Guest
Posts: n/a
I have found mine sound like a jet engine on cold start then quiets down. Think I read its pretty normal.
Old Nov 3, 2012 | 05:35 PM
step66's Avatar
The deal is there is a viscous fluid inside the clutch-if it roars when cold-the fan clutch needs usually needs replacing,because it has solidified,but a strange thing I notice on my Frieghtliner with a Cummins 525 is that the fan clutch roars when the air compressor kicks in,and does the same when the A/C runs at low RPM! But only in warm weather!
HUH? Any explains? Thanks!
Old Nov 3, 2012 | 07:27 PM
newguy's Avatar
Thanks Step
Old Nov 3, 2012 | 09:09 PM
Uh, backwards. When the clutch is cold, it disengages and the fan roars. As the fluid in the clutch warms up, the clutch gradually engages and quiets down. If/when the engine starts to overheat, the clutch disengages, the fan roars, and pulls more air through the radiator. At normal engine operating temperature, the fan pretty much free-wheels. When the clutch is cold, or the engine overheats, it should be spinning at or near water pump rpm.
Learn about how the fan clutch works from howstuffinmycarworks
Old Nov 4, 2012 | 12:17 AM
Jase1979's Avatar
Jase1979 is on a distinguished road
Once again Hook has it right, cold temps the fan will sound like a bear roaring for the first few minutes after that it gets quiet until neccessary
Old Nov 4, 2012 | 03:13 AM
newguy's Avatar
my boss has a 2000 blazer said his doesnt do that. Bugs the crap out of me. May try otherv options
Old Nov 4, 2012 | 06:54 AM
The only other option is an electric fan. Keep in mind that with an electric fan you've got far more things that can, and do fail: thermostat, motor, relay, and the associated wiring and connections. On the plus side, you might notice slightly better fuel mileage and less noise, (only because it moves less air). A thermal fan clutch is far more reliable, moves more air and the overall cost is less, that's why manufacturers use them whenever possible, it's a no brainer.
Old Nov 4, 2012 | 07:11 AM
Logan's Avatar
Logan is on a distinguished road
My C12 cat in my 9400 does the same thing. I think it has to do with the extra load on the motor creates more heat. And I believe the fans are controlled electronically. Some tractors have a fan override switch.
