A Few Questions - LIM replacement
Old Apr 4, 2013 | 01:54 PM
Jesster's Avatar
Jesster is on a distinguished road
Default A Few Questions - LIM replacement
I started to replace my lower intake manifold gaskets and have removed almost everything. I still need to disconnect the fuel lines and remove the distributor.
After reading a few posts I have questions on the distributor. I did not make sure that cylinder #1 was at TDC on the compression stroke. On other vehicles, in the past, it was a matter of not turning the crank while the distributor was out. I have now found instructions from alldata that says if the LIM is removed the engine should have #1 at TDC. Is this really necessary or can I line it back up after marking it? Should I mark the distributor base and LIM with an awl or something that etches so that I don't lose my mark on the LIM?
The fuel lines look fairly easy to disconnect, will I need new gaskets or washers when reconnecting?
Any other tips or pointers from anyone's experience?
1996 Blazer 4.3L LT 4dr 4wd
Old Apr 4, 2013 | 05:44 PM
warthogdriver's Avatar
Joey1986Z
Jun 23, 2014 11:09 AM
Charder
Oct 2, 2012 07:22 PM
kevinph
Feb 26, 2012 09:38 PM
ckirv
Feb 19, 2012 12:07 PM
Jonboy
Sep 26, 2010 04:06 PM
