First post, help with 1999 Blazer (A/C problem)
Perhaps some background info as to when this started is in order. I went to start the truck, wouldn't start, just clicked. Tried jumping, didn't work. A fella who appeared out of nowhere (literally) attempted a jump again with a different set of cables, didn't work. He then tried connecting a wire from the positive terminal directly to the starter (not sure of the technical terminology). This still didn't work. I then had the battery tested, it was bad, bought a new battery and it started up fine. This is when the problem with the A/C started. Piror to this it worked fine and was charged in May/April and have not had any problems since.
Crasy, under what circumstances did yours stop working?
Well, now that i think about it my problem started after i disconnected the battery and reconnected it to fix a problem i was having. I couldnt get the truck to go into 4hi or 4lo until i read online somewhere to disconnect the negative battery terminal then reconnect 5 minutes later. Sure enough it fixed my problem there, but after that my air has been doing the same thing yours has.
You should be able to hear the electronic actuator cycle. It go from its current position to one of the stops, then to the other stop, and finally back to the first stop prior to moving to the appropriate position as determined by the control module for the setting and other conditions (sun load & ambient temperature).
When I turn the key it makes three ticks quickly in a row, then the moaning/squealing sound starts. It is r/t the A/C as the air flow seems to adjust with it. It is doing the same thing, a little cold, a little warm.
