Flex Fan Installation
Old Aug 29, 2017 | 08:13 AM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default Flex Fan Installation
I have a '95 Jimmy with a CPI Vortec. When I bought the truck I didn't notice the flex fan was on backwards. When I took it off and flipped it around, the blades hit my AC pulley. I know I need a spacer. From the water pump flange is about 5 1/2 inches, and I'm supposed to to take off 3 inches, leaving me the option to purchase a 2 and a quarter inch spacer kit.
First time doing this, so I have 2 questions... I have studs sticking out of the flange and the spacer kit comes with bolts, do I remove those studs and if so, how do I remove them?
Next, I noticed that I may need a flex fan spacer adapter, why would I need this? Do I need it or is the spacer kit enough?
Attached Thumbnails Flex Fan Installation-15670009_imp_251510_pri_larg.jpg   Flex Fan Installation-20170829_073136.jpg   Flex Fan Installation-20170829_073111.jpg   Flex Fan Installation-20170829_073213.jpg   Flex Fan Installation-10318830_fle_851_pri_larg.jpg
Old Aug 29, 2017 | 08:23 AM
Default Installation instructions...
Here it says I may or may not need an adapter... I don't think I need one though. Would like an answer from someone who has done this before...
Attached Thumbnails Flex Fan Installation-screenshot_2017-08-29-07-07-22.png
Old Aug 29, 2017 | 08:42 AM
LesMyer's Avatar
Just go to the junkyard and get the correct fan clutch and fan and a radiator shroud. That flex fan is an abomination.
Old Aug 30, 2017 | 12:43 PM
Ok I'm going on the 1st to pull a clutch fan and shroud. What size wrenches do I need to break the fan clutch bolt?
Old Aug 31, 2017 | 07:32 AM
GreenBlazer2002's Avatar
Default I
The fan clutch but on mine was 36mm, but mine is an 02. Not sure if it makes a difference. Hope this helps.
Old Aug 31, 2017 | 11:43 AM
LesMyer's Avatar
Whoever put that flex fan on your vehicle was a moron.
1995 water pump is different from 1996 and later. Your fan clutch does not screw onto the front of the water pump. It attaches to the water pump with four studs, washers, and nuts - just like old times. This is why there are studs left in the front of your water pump. You will need the fan clutch, fan, and shroud from a 1995 Blazer. If you don't have all four studs, washers, and nuts in your vehicle, take what you need from the donor vehicle. Studs are removed by double-nutting them (Google it).
Old Sep 1, 2017 | 10:25 AM
Bought these tools to remove the fan clutch at the salvage yard... Should these work? The fan clutch nut is 36mm and the wrench opens up to 38mm and the big screw driver is 16" long. Which way do I turn the wrench looking from the front of the engine?
Attached Thumbnails Flex Fan Installation-20170901_101227.jpg   Flex Fan Installation-20170901_101311.jpg   Flex Fan Installation-20170901_101414.jpg
Old Sep 1, 2017 | 10:32 AM
Also, my water pump went out and I'm replacing it too.
Old Sep 1, 2017 | 12:52 PM
newguy's Avatar
Oh boy, here we go again. Autoparts stores must love you
Old Sep 1, 2017 | 06:06 PM
Here it is, clutch, fan, and shroud... Replaced the water pump too, no leaks no over heating.
Attached Thumbnails Flex Fan Installation-20170901_162752.jpg   Flex Fan Installation-20170901_172320_hdr.jpg
