which fluid to use for my rear diff ? (pics)
4 Attachment(s)
140,000 miles and I'm sure it's never been changed....So I'm gonna change my rear end fluid today. Which oil should I use ?
Here's the sticker in my glove box https://blazerforum.com/forum/attach...ine=1363702420 80w90 Limited Slip https://blazerforum.com/forum/attach...ine=1363702420 80w90 https://blazerforum.com/forum/attach...ine=1363702420 Thanks. |
I don't see the G80 RPO on your sticker so you should just stick with the standard gear oil, not the one for limited slip diffs.
(Post 574155)
(Post 574155)
Originally Posted by 97cherryblazer
(Post 574173)
Ill comment here just so everyone knows. If you have a G80 you don't need any fancy limited slip fluid. There are no clutch plates in a G80, It requires the same fluid as a normal diff. Hope this helps anyone in the future!
So I'm looking for a straight 80w90 gear oil that doesn't say anything about limited slip.(like the old bottle in the last picture) Went to NAPA and Autozone and all they had was 80w90 "limited slip" Both These places said oil companies like Valvoline are only making the limited slip kind now a days, because you can use them in both posi and limited slip rear ends. Anyone have any input on this or know of a good oil i should use ? |
Originally Posted by blazinjay83
(Post 574186)
Ok, thanks.
So I'm looking for a straight 80w90 gear oil that doesn't say anything about limited slip.(like the old bottle in the last picture) Went to NAPA and Autozone and all they had was 80w90 "limited slip" Both These places said oil companies like Valvoline are only making the limited slip kind now a days, because you can use them in both posi and limited slip rear ends. Anyone have any input on this or know of a good oil i should use ? BTW, if you have never done a rear end in the past, prepare for quite the stench!! :icon_toliet: |
Gotcha....thanks for the clarification.
3 Attachment(s)
With the rear end I have, would this be a good oil ?
https://blazerforum.com/forum/attach...ine=1363723786 https://blazerforum.com/forum/attach...ine=1363723786 https://blazerforum.com/forum/attach...ine=1363723786 Anyone ever used this before ? |
That would be fine. The manual calls for either 75W-90 or 80W-90. I've been told that the 80W-90 is better for a warmer climate, and the 75W-90 for colder, but you won't go wrong with either. I live in the frozen wasteland of Canadia and am running 80W-90 cause that's all I could find for a reasonable price. I am not an oil specialist, and the majority of my information comes from people on here, past and present.
(Post 574201)
does it only take one of those bottle to fill it |
| All times are GMT -5. The time now is 01:33 AM. |
