Flushes
Old Oct 19, 2007 | 01:21 PM
gohan69's Avatar
gohan69 is an unknown quantity at this point
Default Flushes
How often should coolant flushes be done and how often for diff flush my blazer has 75k on is it due for all the flushes?
Old Oct 19, 2007 | 01:34 PM
Default RE: Flushes
With a 2001 (found that through your other posts), you are over due for a coolant flush & refill if it has never been done. If your cooling system has maintained its integrity, then the coolant should be a simple drain, flush with a hose, then distilled water, and refill.
On the diffs, it won't hurt anything to drain and refill them. The rear diff requires a new gasket and while you're in there, you should clean it out well before filling it back up.
