-   -   FOUND a code scanner that WILL work on a 95 (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/found-code-scanner-will-work-95-a-19679/)
95LS Apr 13, 2008 12:14 AM
as many of you might have read i have been looking for a handheld code scanner that will work on a 95. i finally found one. i was looking at the equus 3140 but after calling them they told me it will no t work. Actron CP9190 will work. i looked at the pdf of their manual and it is listed as a supported vehicle. they said some 95's use a 16 pin OBD II connector but it is OBD I compliant (im guessing thats why the equus wont work for some strange reason if it has the capability/connectors for both OBD I and II i dont see why it wouldnt). i wish the equus would work i have a compression/ fuel pressure tester, vaccum guage, LED timing light (even has idle RPM's and the timing advance on screen) i will buy their fuel pressure tester as well i havent had any problems with them so far. looks like im going to have to settle for actron. but at least i will have one when i need it. has anyone used any other handhelds on their 95's ? please post somments about them.
95_4door Apr 13, 2008 11:55 AM
RE: FOUND a code scanner that WILL work on a 95
Any of actron's scanners that are obd2 will work. They have been programmed to work with the obd2 transition. We sell them at work and I have tried most of them on my truck and haven't had any problems.
95LS Apr 13, 2008 11:27 PM
that makes me feel a little better. thanks for the imput. can u get me a discount ?
