found a vacuum hose near the oil filter, need help!!
Old May 19, 2013 | 06:49 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default found a vacuum hose near the oil filter, need help!!
when i was checking my oil filter lines for leaks, i noticed a vacuum hose dangling down. it wasnt cut straight, like the tip was angled off at maybe a 30 to 45 degree cut. what could it be from? or is it supposed to be just randomly dangling?
Old May 19, 2013 | 07:56 PM
abig84's Avatar
could be for the 4wd switch back at the transfer case. if you get time post some pictures that might help people figure out what it is
Old May 20, 2013 | 07:30 PM
er0ck273's Avatar
i have the pictures ready to go. everytime i try adding them as an attachment and uploading it, it says uploading please wait...then that box goes completely white and eventually exits...i dont get it
Old May 20, 2013 | 07:45 PM
richphotos's Avatar
Does your 4wd work? if it does, its not anything to do with that.
Old May 20, 2013 | 07:50 PM
coolasice's Avatar
coolasice will become famous soon enough
more then likely from your secondary air injection pump valve....
Old May 20, 2013 | 07:54 PM
er0ck273's Avatar
im going to go check the 4wd right now. i just heard the horror stories of getting it stuck in 4wd lol, only one way to find out
Old May 20, 2013 | 08:04 PM
er0ck273's Avatar
the 4wd works perfectly, i forgot how much of a punch it packed lol. now saw it was the secondary air injection pump valve, what affects would i be expecting?
Old May 21, 2013 | 06:31 AM
coolasice's Avatar
only effect would be a vavuum leak and a ses light on
tazz9690
Aug 21, 2019 10:01 PM
stereomike
Sep 19, 2012 05:07 PM
stlwaco
18
Dec 21, 2011 03:55 PM
greendouglash
Feb 16, 2011 08:46 PM
shooter2499
Feb 4, 2008 09:23 PM
