Front Brakes Dragging
Old Sep 25, 2009 | 10:16 PM
JOHNNY59's Avatar
JOHNNY59 is on a distinguished road
Default Front Brakes Dragging
My 95 blazer 4x4 front disc brakes are dragging. Sometimes I can feel them holding the truck back when driving and I can smell that burning brake smell. Other times they're fine. The last time they were dragging I jacked up the front end and tried to turn the front wheels and both sides were hard to turn.Came back in about an hour and both wheels turned freely. Why would both sides drag at the same time and then turn freely at the same time? Calipers,brake hoses,master cylinder,proportioning valve,ABS.
Thanks for any help
Old Sep 25, 2009 | 10:21 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
the calipers when heated up are staying partially applied check to make sure the calipers are releasing and check the front hoses..i have seen them allow fluid through but collapse and not let enough fluid back out causing brake drag.
Old Sep 25, 2009 | 11:41 PM
JOHNNY59's Avatar
Would that cause both of the front brakes to drag at the same time?
Old Sep 25, 2009 | 11:59 PM
young murph's Avatar
young murph is on a distinguished road
check caliper pins and collapsed or kinked flexible brake line
Old Sep 26, 2009 | 12:31 AM
terry s's Avatar
terry s is on a distinguished road
When they are dragging open the bleed screw. If it stops dragging the hose has collapsed inside and is acting like a check valve and not letting all of the pressure release when you let off the brake. I would be surprised to see both sides do this at the same time though.
Old Sep 26, 2009 | 12:36 AM
old skool luvr's Avatar
yeah, i'd be surprised too terry. take out your slide pins, clean them really well, and reinstal them with some Cop-A-Slip from Moly Slip-best brake component lube out there (been using it since Christ was a dude rancher).
Old Sep 26, 2009 | 09:58 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
It's possible that both calipers are bad. When's the last time you did a brake job?
Old Sep 26, 2009 | 12:15 PM
terry s's Avatar
Possible but like the hoses not likely for 2 to go bad at the same time.
After you clean & lube as old skool said then you can put the caliper back on with out the pads. Then the caliper should slide easily back & forth if all is ok with the pins etc.
Old Sep 26, 2009 | 01:09 PM
JOHNNY59's Avatar
Put new pads on about a month ago.Cleaned pins,slides and lubed them.
Old Sep 26, 2009 | 04:43 PM
Were they dragging before that?
I had two calipers freeze up on a Toyota Camry after doing a pad and rotor replacement on it. Crap loosened up in the lines when I pushed the pistons back in and was fed back into the calipers, making them stick.
