Front differential click
Old Nov 4, 2018 | 04:10 PM
cb96's Avatar
cb96 is on a distinguished road
Default Front differential click
Click coming from the front
only happens in 4x4 or 4auto
its a 2005 with an automatic
doesnt happen in 2wd. The light stays on so I am assuming the 4x4 is working but I’m scared to really test it. Research is leading me to believe it’s the carrier bearing? Any way I can test or confirm before ripping the half shaft out?
words of wisdom appreciated. I’m in a pinch.
Old Nov 6, 2018 | 12:52 PM
cb96's Avatar
Anyone alive out there????
Old Nov 6, 2018 | 02:18 PM
There's a tech article that covers the more common occurrence of this where it clicks in 2wd, but not in 4HI/Auto4wd and it likely is the same problem; a sticking or worn engagement collar inside the front axle. It could also be a sticking engagement cable as well. The tech article shows you what's in there and how to diagnose the issue.
Old Nov 7, 2018 | 10:13 AM
cb96's Avatar
Thanks for the response. Do you have the article handy? Since you’ve seen it before, maybe you can point me in the right direction. Might be a sticky? I’ll look around.
959900s10blazer
Shows & Clubs
Jan 31, 2019 01:08 PM
AlwaysWanted1
Feb 25, 2018 10:22 PM
loganreeves
Performance & Brainstorming
Mar 30, 2009 10:13 AM
EuroGoldLS
Detailing
Jun 5, 2007 01:07 AM
