front differential gear lube change for 1997 Blazer
Old Apr 8, 2011 | 07:58 PM
remm jake's Avatar
remm jake is on a distinguished road
Default front differential gear lube change for 1997 Blazer
I would like to change the front differential fluid on the 1997 S-10 4WD Blazer. Is this a difficult thing to do? Is there a drain plug? How do you drain the fluid? I see the fill plug in the manual.
Thanks.
Old Apr 9, 2011 | 10:22 AM
racsan's Avatar
racsan is on a distinguished road
when i changed mine i used a small hand pump (meant for putting oil in a differential) and pulled as much oil out as i could through the fill hole, then refilled with fresh oil. did the same with the rear. must have been low on oil, because afterwards i had a oil leak at the axleshaft seal on the left side. once that was took care of, its been fine for the last 10K miles. rear axle also had a oil leak so a couple of weeks ago i took the back cover off, did both axle seals and cleaned out the differential real good before refilling with oil. need to pull the drums off and see if i have any leakage, hopefully not, the axleshafts were scored up pretty good and i may end up swapping rear axle assy's with my parts blazer if im still oiling my brakes.
gmbwrenchn
Oct 28, 2009 10:47 PM
wienerdog
Nov 4, 2008 04:40 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
USMaverick101
Dec 1, 2006 12:45 AM
Binz316
Apr 12, 2006 12:55 PM
