front door latches..doors won't shut
Old Nov 28, 2006 | 03:10 PM
dankolbenschlag's Avatar
dankolbenschlag is an unknown quantity at this point
Default front door latches..doors won't shut
My door was frozen shut this morning..I yanked it open. It will not shut now. The door latch mechanism (where the bar goes into the metal parts and latches shut) is stuck down. It won't move back up. I went to the passenger side to look at how it works, I pushed that one down and it will not go back up either..It's snowing outside and I need to fix this..HELP
thanks
Old Nov 28, 2006 | 03:17 PM
Joey P.'s Avatar
Joey P. is an unknown quantity at this point
Default RE: front door latches..doors won't shut
Just try and open the door handle like it was closed and you were trying to get it to open. That may do the trick.
Old Nov 28, 2006 | 03:41 PM
You may have to heat the latch mechanism to free it up. Sounds like you got some water in around the latch and it has frozen it up good...
Old Nov 28, 2006 | 03:59 PM
Got it solved! I found out if you hold the handle up and get a screwdriver you can push the lock mechism back into position. Of course I found this out an hour later..after the inside of my blazer is covered in an inch of snow. Oh well. Thanks
Old Nov 28, 2006 | 04:03 PM
Ah ok. I was misunderstanding your situation. I thought the latch was stuck 'open', not 'closed'.
Glad you got it fixed!
ProjectICE
Jun 21, 2011 03:22 PM
juddkennedy
Dec 28, 2009 01:35 PM
bhm3948
Mar 31, 2009 05:53 PM
celchlepp
Feb 17, 2008 03:56 PM
dropd4door
Feb 10, 2006 02:34 PM
