front drive shaft
Old Sep 27, 2007 | 05:18 AM
AL's Avatar
AL
AL is an unknown quantity at this point
Default front drive shaft
I have a 2002 2dr 4x4 blazer, and i was wondering if the front short drive shaft should be spinning when in 2 wheel drive,and if it does do the front wheels make it spin.
Thanks Al
Old Sep 27, 2007 | 07:07 AM
soundguy's Avatar
soundguy is an unknown quantity at this point
Default RE: front drive shaft
The left and right axles will spin full time of course. As for the driveshaft from the TC to the diff, I think that sincethe engagement mechanism is located on the front diff itself, the front driveshaft (from TC to diff) would not spin unless 4x4 is on. Maybe someone could confirm this, but I think that's how it goes.
Old Sep 27, 2007 | 08:03 AM
sound, you are correct. The front driveshaft should not spin when in 2wd. Something is either causing the transfer case to be in 4wd or the front axle to remain engaged which is causing the front driveshaft to spin.
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
blazer_95
Feb 26, 2008 11:22 PM
cwiththehad
Sep 5, 2007 01:14 PM
wormburnr
Nov 4, 2006 03:42 PM
