Front End Align Spec
Old Oct 14, 2013 | 09:00 AM
cferry7's Avatar
cferry7 is on a distinguished road
Default Front End Align Spec
Where could I find the true manufacturer specifications for Camber Caster and Toe In for my vehicle. ?
And steering axis inclination spec for cornering
; possibly named the Roll spec. ?
1995 1/2 Gmc Jimmy 4WD
Cferry7
Old Oct 14, 2013 | 08:11 PM
Straight out of the GM "dealer issue" shop manual:
0 degrees camber
+3 degrees caster
+0.1 toe
0 SAI
EDIT: Get camber and toe dead nuts, caster can go as low as +2 degrees with no problems, but no higher than 3 degrees. If you go less than +2 caster it will tend to wander. If you go more than +3 degrees, you'll end up with camber roll, (caster induced change in camber).
Old Oct 15, 2013 | 03:48 AM
da67goatman's Avatar
da67goatman is on a distinguished road
I would advise against toe in as every vehicle i've ever had with "factory" spec alignment had uneven wear especially 4wds. I adjust the specs to suit me and the vehicle. -0.5 to-1.2 camber depending on vehicle with absolutely no toe in front sometime slight toe in at the rear if its twitchy.
Old Oct 15, 2013 | 01:00 PM
cferry7's Avatar
Great Information !
Thank you
Old Oct 15, 2013 | 03:19 PM
Rule of thumb with toe, is RWD & 4WD should be set slightly positive, and FWD should be set slightly negative. When RWD & 4WD vehicles are in motion, toe goes toward negative. If it goes past zero, the inside edges will wear prematurely. When FWD vehicles are in motion toe goes positive. If it goes past zero, the outside edges will wear prematurely.
puttster
Nov 17, 2015 08:07 AM
yuka42
Apr 28, 2014 07:45 PM
BLAZER97LS
Apr 16, 2012 02:56 PM
patterrr
Apr 2, 2011 10:09 AM
2001Blazer4x4
Mar 2, 2005 10:45 PM
