front rearend not locking in
Old Jan 17, 2019 | 03:43 AM
Mike.308's Avatar
Originally Posted by ernies 2000
is this the sensor that plug's in right above the cable?
That's right.
Old Jan 17, 2019 | 11:28 AM
ernies 2000's Avatar
ernies 2000 is on a distinguished road
Thank's everyone
Old Jan 17, 2019 | 12:20 PM
cleburne red's Avatar
One thing it might be, if the vacuum actuator is pulling, but it's still not engaging, is the gear in the passenger axle coupling could be chewed up. I ran into that
This is what the setup looks like:
On mine, one of the gears was chewed up, preventing the collar to engage
Bought a new gear (I believe it's just called a "connector") and I have 4wd again. I want to say it was around $70-$80 from gm parts direct.
Old Jan 17, 2019 | 09:38 PM
Thank's Cleburne , that's exactly the pic's i was looking for. I think this is what happened to mine. im tearing into to it saturday, i will know then, and ill check back in.
Old Jan 18, 2019 | 05:01 AM
No problem man! I should have posted them earlier, just didn't think of it
Old Jan 18, 2019 | 12:14 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Ive seen the vacuum hose disconnected at the ball in the drivers fender and the actuator would pull enough to fool the sensor but not enough to lock the diff .
Old Jan 19, 2019 | 11:36 PM
thank's guy's for the info, now ive got a bigger problem. i've lost the cable clip retainer, cant find it anywhere, Does anyone know the exact name for them? Or where i can buy them?
Old Jan 20, 2019 | 05:45 AM
Mike.308's Avatar
I tell You what I did, when I've lost the retaining clip for the oil line. I took the other one to a local spring producer shop. Asked him if he could make me a copy. He smiled at me... He had no time to do, but gave me the spring wire of the exact diameter. Told me to get the desired shape using pliers and then temper it in about 150 degrees for half an hour. I did so and the clip is fine for over 1500miles. So if You could get the spring wire somewhere....
Old Jan 20, 2019 | 03:59 PM
Thank's mike, if i cant find them somewhere to buy i may have to go that route. I cant even find a pic of them online. Someone has to sell them somewhere.
Old Jan 20, 2019 | 04:36 PM
Mike.308's Avatar
IDK if they are sold separately. Probably they come together with actuator only. They are not expensive (afair about $50), but perhaps someone here could drop a photo and u could make a copy out of a spring wire...
