Front UJoint Cap bolts
Hi,
I'm trying to find a substitue to my rounded bolts.. I'm not sure where to find it tho.. I don't think Canadian Tire have this, I didn't even ask them but I wanted to buy online if possible.. I've looked at fastenal.com but I don't see what I need..
The bolt MinDia is 0.277inches Major Dia 0.306inches
From what I see the bolt is 0.0416666 pitch (24 threads per inch)
The bolt length minus the head is 33mm and the thread length 21 mm
It's the 11mm head bolt on the ujoint caps.
Is that a common bolt that I could find anywhere?
I think what I'm going to do is buy allen bolts that will not round off and I believe the correct size is 5/16 x 24 x 1" 3/4 if I'm not mistaken..
That one sounds good, any thoughts?
5/16"-24 x 1-3/4" Black Oxide Alloy Steel Socket Cap Screw | Fastenal
Autozone or Advance should have these in stock- it's called a strap kit. I think it's P/N 81000.
Nice!! Thanks that's exactly what I'm looking for!
Personally, I wouldn't use just any old bolt. Your driveshaft takes alot of abuse. Get the strongest ones you can find.
i would think allan bolts would be worse. everytime i ever tried to get any of those things off that been on a vehicle for 15 years they round out from the inside
drummerdude
11-13-2009 09:11 PM
matclark
07-03-2008 08:04 AM
