Fuel delivery problem
Old Nov 24, 2013 | 09:11 PM
tomwillie12's Avatar
tomwillie12 is on a distinguished road
Default Fuel delivery problem
I have been struggling with a 2000 w/ 4.3 4wd that stumbles badly and nearly cuts off when starting from a stop. I have replaced the fuel pump and filter and still only get 58 lbs. of pressure. Today I pulled the plenum and found that the inside of the plenum and the manifold are black. I did not find any leaks or smell any fuel but something has caused it to carbon up. Any ideas? Also need to know how to check the poppets.
Old Nov 24, 2013 | 10:04 PM
richphotos's Avatar
you checked the pressure, did you do the leak down as well? should not drop below 55psi in 10 minutes.
are their any stored codes? bring it to a parts store and have them scan to see if there are any check engine codes.
Old Nov 25, 2013 | 11:36 AM
Pressure is 58 and holds at 55. There are no codes.
Old Nov 25, 2013 | 01:31 PM
rexmburns's Avatar
Super Moderator
You need 60-66psi not 58.
Old Nov 25, 2013 | 01:55 PM
chris015's Avatar
ehhh. id say 58 is maybe ok.
Change your fuel filter and test again.
you said u replaced the pump....with what? (brand)
Old Nov 25, 2013 | 02:18 PM
spittybays
Guest
Posts: n/a
Any chance you could get your hands on a different gage?
From what I have seen most low feel pressure problems start to manifest as long crank to start time.
Like Chris said fuel filter could make it starve when you step on the gas.
It sounds strange but all carboned up and ugly is kind of what you want to see under there. Shiny spots mean you have gas spraying someplace.
Old Nov 26, 2013 | 05:14 PM
When the EGR valve opens, it fills the entire plenum with exhaust gas, that's why it's black...perfectly normal.
If the 58psi reading is accurate, it's too low and you will have driveability issues caused by a lean mixture. As Jeff mentioned, "Any chance you could get your hands on a different gage?"
As rexmburns mentioned, with fuel pump running, engine off, pressure must be 60psi to 66psi. Must remain above 55psi for at least 10 minutes after the pump shuts off.
Old Nov 27, 2013 | 01:57 AM
Fuel filter is newly installed, no miles on it. Used a second pressure gauge and got same results. Fuel pump is Delco. Holds pressure at 55. Is there a way to check the regulator with a vacuum pump while off the spider?
Old Nov 27, 2013 | 08:53 AM
spittybays
Guest
Posts: n/a
Not really because that fpr works in a vacuum environment under the plenum. Your going to have to get a piece from Dorman, think they call it a fuel line repair kit. Its a short connector that will give you the ability to connect your gage right to the fuel filter. If you get the correct pressure there then the fpr is opening to early.<br />
Almost positive its Dorman 800-121
Old Nov 27, 2013 | 12:56 PM
Spittybays is exactly right. All pressure and flow from the pump must end at the gauge. The Dorman # is correct. With the pump running, pressure must be 73psi to 108psi. It must remain above 55psi for at least 10 minutes after the pump shuts off. If it passes both parts of this test, the regulator is at fault. If it fails one or both parts of the test, the pump is at fault.
