Fuel gage
Old Sep 8, 2008 | 09:17 PM
Nelubez's Avatar
Nelubez is an unknown quantity at this point
Default Fuel gage
Wouldn't you know. I just finished replacing the fuel pump in my 96 S-10. During this process, though no fault of my own, (or I did do it, hell i don't know) something happened to the fuel gage. It's not reading the right level in the tank. The half tank mark is my new empty. Now granted this is no major problem, but it annoys me. What did I do? and how can i fix it?
Thanks.
Old Sep 9, 2008 | 07:09 AM
Default RE: Fuel gage
If the ground connection to the tank (sending unit) was compromised, this could cause an incorrect reading.
Was the sending unit replaced with the rest of the fuel pump assembly? If so, it is also possible that you got a defective unit.
Old Dec 18, 2008 | 07:50 PM
tomcatguy's Avatar
tomcatguy is an unknown quantity at this point
Hi, wondering if you might be able to help me w/ a fuel system question. Am getting the low fuel light on my 2000 Blazer at about 175 miles. It generally takes about 14.5 gallons, making the mileage around 14+ - not too bad during the winter.
So why would I get a low fuel light with approx 5 gallons left in the tank?? (just had the fuel pump replaced by a prof mechanicdue to low fuel pressure).
Any ideas??
Old Jan 3, 2009 | 01:59 PM
blazr4.3's Avatar
blazr4.3 is an unknown quantity at this point
I don't know about you, I think the sending units are frail or something.
Not long after I bought my 2000 blazer, the fuel gauge went south. It will stay on full for about a half a tank, then it will bounce every so often. When its starting to get really low it will bounce often and fast. I usually go by mileage and after 300 just fill it back up, no big deal. The dealership told me it would be around $500.00 to fix it, I don't feel like messing with it, and it just isn't worth it to me. Anyway, just thought I would share my thoughts.
Old Jan 23, 2009 | 06:44 AM
bandidolenny's Avatar
ORIGINAL: Nelubez
Thanks.
You may have lost a decent ground to the dash cluster... is this the only gauge that is actng up?Either way,check yourfuel pumpand dash harness connections, ground straps, etc...
Old Feb 26, 2009 | 02:08 PM
GGA's Avatar
GGA
GGA is an unknown quantity at this point
Did you bend the wire supporting the float rod?
Jerry.rm125
Sep 4, 2014 02:45 PM
19ruler76
Mar 5, 2010 03:00 PM
swizznuker
Feb 19, 2010 11:55 PM
d666
Nov 13, 2008 09:25 PM
NCStone
Jul 15, 2006 02:52 AM
