fuel inj. trouble
Old Apr 6, 2011 | 10:56 PM
tim68's Avatar
tim68 is on a distinguished road
Default fuel inj. trouble
i have a 02 blazer with a 4.3 it has a miss fire on cyl. 3&4 at idle, as soon as you take off the miss fire goes away. i have replaced the timing chain, wires, plugs.dist. cap and rotor. I was wondering how hard it is to change the injecters on those cylinders. also my distributer is making a noise sometimes but it runs no different with or without the sound,sounds like the shaft is vibrating inside the distributer, can your distributer give you miss fires on just a couple cylinders. any help would be appreciated. Thank You
Old Apr 6, 2011 | 11:33 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
how many miles on it, have you had the codes pulled, checked the fuel pressure?
Old Apr 7, 2011 | 12:27 AM
tim68's Avatar
Sometimes I get code 0300-0303-0304 at different times it has 120,000 miles. I put it on a scanner and cyl.3-4 miss fire at idle give it gas and it quits, has a new fuel pressure regulator and intake gasket
Old Apr 7, 2011 | 08:37 AM
If you have to replace 2 or more injectors, you really should look at doing the MFI conversion (search "MFI+conversion").
P030x - Random/Multiple Cylinder Misfire Detected will get you the diagnostic chart as well as a link to a thread where the P0300 code is discussed to the n-th degree.
Puffie40
Dec 24, 2014 09:04 PM
sparcky1
May 12, 2011 05:32 PM
yoak19
Apr 7, 2009 08:46 AM
ineedspeed7
24
Jan 11, 2009 09:31 PM
wythel
Aug 9, 2006 02:10 AM
