Fuel Line Confusion 1998 Blazer
Old Jul 24, 2021 | 03:37 PM
pimpin's Avatar
pimpin is on a distinguished road
Default Fuel Line Confusion 1998 Blazer
My fuel lines got bent up during an engine swap on my 1998 S10 Blazer , does anyone know if it should be right or left side for the Supply.
I am making the assumption the larger tube is for the Supply and the Smaller is Return, So if I were looking at it from this view would the supply be on the left or right(the bigger one)?
Thanks for any help.
Old Jul 24, 2021 | 04:16 PM
It looks like the bigger line goes on the distributor side. Checked both blazer and sonoma...
Closest to the firewall is the \"smaller" one, connected to outer side. Bigger is closer to engine and goes to distributor side
Old Jul 24, 2021 | 06:41 PM
pimpin's Avatar
Default thanks so much
thanks, I was scared there this morning.
But I think you are absolutely right, I think that is the only way they can go on,
because that little black plastic valve thing is on the left side looking at it and thats to bleed the supply Im pretty sure, so fingers crossed I should be good.
Anyone reading this, BEWARE during an engine swap on this truck make sure the fuel lines are in the center when you drop the engine in.
I had them deep down on the divers side and they virtually cant clear the engine to be brought to center.
Old Jul 24, 2021 | 08:26 PM
It's not to bleed, as much as it is to check the fuel pressure coming from the pump lol...
Hosseios
May 4, 2021 02:21 PM
Big'n
Oct 31, 2018 06:50 PM
bwatson
Jun 4, 2013 08:52 PM
ronidog12
Nov 10, 2010 06:21 PM
delilah4no3
Sep 5, 2009 12:30 PM
